Saturn_Europa
- Fishing Industry
- Electrician Limited License NC, QMED Electrician
Has this ever happened to anyone?
I was fishing a 2" conduit with about 20 wires in it. Its all 14 gauge control wiring. Its about a 30 foot run. I tried my nylon tape and got nowhere. So I brought out my steel tape that has a hook bent into the end. I got the tape 23-24 ft in and could not get it any farther. So I tried to pull it out and it is apparently wrapped around a wire. Its pretty darn stuck. I got out my second fish tape, cut the hook off and tried to fish it from the other side. It wont fish that way either. Its two inch rigid conduit with a PVC coating, and I have no clue what it does underground. I assumed it would be a pretty easy pull.
I cut the ground wire and tried to use that as a pull string. But it only pulled 2 ft before it stopped and would not move at all. I think all the conductors are taped together.
Any suggestions on how to get out the stuck fish tape? My only thought is to shut down the plant and cut all the control wires and pull them out together with the fish tape. Then pull them all back into the wire gutter and butt splice them there. But its pretty risky and I have had bad luck with this conduit so far. Or just cut the fish tape and know never to try to pull wire through that conduit.
