Working on a design for a fishing pier in a residential area. I believe the pier will be shared with the public as well. I’ve been searching for lighting requirements, I thought lighting was required since it’s in an area of water that boats travel. There is no other shore power that will be provided on the pier. The owner wants to keep the lighting minimal and only do what’s required by code. I looked through the areas zoning requirements, I didn’t see anything. The plan has been submitted for a zoning approval and there was no mention of any lighting to be addressed in the response to the submission which listed conditions to be addressed.
Can someone direct me to any code requirements , coast guard etc that may give me some info. Even if nothing is required I would still
Like to propose the standard practice if there is one. If I had to finish it up quickly with no additional research, I think I will put two red signal lights (as close to the datum
Line As possible per section 555) and two pathway/bollards at the end of the pier for security/safety.
Any help is appreciated
