Coppersmith
- Tampa, FL, USA
- Electrical Contractor
A past client called me up to say the power was out in four bathrooms all controlled by one GFCI. She said the reset button was hard and could not be pushed in. (She made it sound like the button would not move, i.e. frozen.) I asked her if she had checked for a tripped breaker and she said yes. It stopped working when she ran the vacuum she had plugged into the GFCI. She said the GFCI was bad and needed replacing. Based on our conversation I agreed and made a service call.
I press the reset button and it's not frozen, it just won't lock-on meaning there is no power to device. I go to the garage which is literally 5 paces away and check the breaker panels. (There are two side-by-side. A big one and a much smaller one.) There I see a tripped breaker which I reset and then verify that the GFCI is again functional. "Uh-oh" I think. "This is not good. I've been here two minutes but I have to charge for an hour. She's probably not going to be happy."
I make a show of checking the other bathrooms with a tester and then check the kitchen receptacles. "Unfortunately", everything is wired correctly and working. Now comes the moment I was dreading. "I fixed the problem. It was a tripped breaker." She wants to see where this tripped breaker is located and I show her a spot in the small panel. "I checked the big one" she says. "I didn't know there were circuit breakers in there" pointing at the small one. I just nod my head.
I charge her for a minimum service call (one hour plus travel charge). "That will be $XXX. Sorry" I say. She doesn't say a thing while she writes the check, but I can see she is annoyed. I'm not sure if she is annoyed at me or herself. Guess I'll find out if she ever calls for my services again.
I've been advised in the past to change the breaker or GFCI in these kinds of situations just to make the client feel better. Maybe I should have, but it feels dishonest to me since I would have to charge even more to cover the material. Thoughts?
