Coppersmith
- Tampa, FL, USA
- Electrical Contractor
As part of a larger job, I recently quoted installing two chandeliers. I asked the standard questions about ceiling height and chandelier weight. Both were going into existing lighting outlets. No fixtures had to be removed. Armed with this info I quoted one for 90 minutes labor and the other for two hours. I know that some chandeliers have crystals or whatnot (drops) that have to be hung. But, I’ve never had to spend too much time doing it. Well, this time I did and it turned the job into a disaster.
First I did the 10 foot ceiling fixture. The base fixture went up fast enough, even with the homeowner spending 10 minutes debating the correct fixture height. Then I had to hang the drops, 96 sets of three glass balls. There was a ping-pong sized ball, an apricot sized, and a orange sized. All 288 balls rested on each other making the fixture look like a floating pile of foam. Some “fluffing” was necessary to get it to look balanced. That fixture took 2.5 hours, an hour more than planned.
I had about 2.5 hours left in the day and was debating starting the other chandelier (which I quoted at two hours). I asked the homeowner if it had a lot of drops like this first one because I didn’t want to stay late to finish it. “No” was the answer, but I decided to call it day anyway. That turned out to be a good decision.
The next day I start the other chandelier which is over a stairway landing and 15 feet up. As I’m unpacking the box I come across bags and bags of mollusk shells. Uh oh. I find the assembly instructions. There are 19 strings of 43 shells tied together with fishing line. There are also 288 drops consisting of two shells. The shells have a good side and a bad side so as I’m hanging these, I have to flip shells over to the good side. Of course, many of them don’t want to stay and flip back. This “two hour task” took four hours.
A fixed price job is just that, so I worked for cheap. Needless to say, I will now ask more questions about drops when quoting and I suspect I will be doing a lot fewer complicated chandeliers since the added labor will make my price very high.
