GerryB
- woodbridge, ct. USA
Had a job today a customer had a circuit not working and it was a lost neutral. (where do those guys go?) When I have one of these I ground out the neutral to see if it restores everything and then try to find it or refeed it. In this case there was a basement light 20' from the panel involved so I ran a 14-2 from the light to the panel, hooked up the ground and neutral and all was well. I was thinking maybe I should splice the hot in also at the light and tape it in the panel, or change the hot in the panel and tape the removed wire, (since that would be backfed), or put both wires to the breaker, (then the circuit would be fed 2 different ways). How do some of you deal with this? What I did took almost two hours. To actually find the problem would have involved moving furniture, 10 or 12 switches, recess lights, hanging lights, and surface lights.
