Plumber called me and needed a 20 amp sump pump circuit installed underneath the eletrical panel in the basement (an easy one he said!!) it needed to be done in the morning, I took the permit out and headed to do the job, it turns out the panel was a ML sub panel, it was fed with 4- #6 cu conductors, the neutral and ground were under the same lug, now... I straightened up the wiring and seperated the grounds and neutrals in the sub panel, I installed my circuit under it, that was sump pump # 3 in this house, but the discharge pipes all run about 18" in front of this sub panel, I am not sure if it will pass inspection??? but the plumber is not moving them, they were exsisting he said. Anyone else run into things like this, that you have to fix to do your job? I know I should have looked at it first but wanted the permit in hand before I started, the rule around here!!
