If LED drivers don't show amps there's a problem. Notice the UL standard below for product markings that are not optional.
Here's part of the standard requirements from UL White Book
DRIVERS FOR LIGHT-EMITTING-ARRAYS, MODULES AND CONTROLLERS
(FKSZ)
PRODUCT MARKINGS
LED drivers are marked with:
a) Input voltage, either the supply (line) voltage or a low voltage (ac or dc)
b) Input current
c) Input wattage, power factor or both (optional)
d) Output maximum voltage
e) Output current (the maximum current that could be supplied by the driver)
f) Output volt-amperes or wattage
REQUIREMENTS
The basic standard used to investigate products in this category is ANSI/UL 8750, ‘‘Light Emitting Diode (LED) Equipment for Use in Lighting Products.’’
UL MARK
The Certification Mark of UL on the product is the only method provided by UL to identify products manufactured under its Certification and Follow-Up Service. The Certification Mark for these products includes the UL symbol, the words ‘‘CERTIFIED’’ and ‘‘SAFETY,’’ the geographic identifier(s), and a file number.
Alternate UL Mark
The Listing Mark of UL on the product is the only method provided by UL to identify products manufactured under its Listing and Follow-Up Service. The Listing Mark for these products includes the UL symbol (as illustrated in the Introduction of this Directory) together with the word ″LISTED,″ a control number, and the product name ‘‘LED Driver.’
