markjkubicki
- New York City
there is so much on this topic online that my head spins; what i can't find online is a simple yes/no (if one even exists)
If I install a simple downlight in the lay-in tile of a suspended ceiling, does it need to be 'supported from structure' ?
What i've always been told is 'yes', ether by fastening to the grid or from building structure. BUT... I cannot find the code that states this to be true (only a lot of maybe, and depends, and varies... often with siesmic concerns and/or a volley between the NEC and NFPA)
and if true, and i presume so, how does this apply to the current LED based range of fixtures? Not implying that the LED technology has anything to do with it, but that the fixtures are often class II, often without a housing or mounting pan
as an example: https://www.inter-lux.com/products/quantum/
