Alwayslearningelec
- NJ
- Estimator
I'm never 100% on a project that has to be 100% EMT whether whips can/are used?
In my opinion I think(obviously...lol) the mounting of the fixture matters.
If it's surface, I assume you may be able to pipe directly in/out of fixture, correct? If not, would you say a short FMC whip could be used to get over to a J-BOX? Remember I'm referring to a job that all wiring is to be in EMT.
If it's pendant that brings a few variables for wiring method out of fixture.
If it's rigid stems then wiring can be brought from the 4" box the stem mounts to, through the stem, directly to fixture. Then you just bring your feed to that stem mounted 4" box.
If it's chain or aircraft cable mounted, then I'd think a FMC whip would be needed to a 4" box, correct? If you do that then you could maybe have (1) 4" box for 2 fixtures.
I know I overthink things too much.
