Fixture wiring
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
The code allows it. If you are talking feed thru then the fixture must be listed for the purpose. If you are just using a double connector and going in and out then you should be fine.
jumper
Just adding to Dennis' post:
410.64 Luminaires as Raceways. Luminaires shall not be
used as a raceway for circuit conductors unless listed and
marked for use as a raceway.
410.65 Wiring Supplying Luminaires Connected Together.
Luminaires designed for end-to-end connection to
form a continuous assembly, or luminaires connected together
by recognized wiring methods, shall be permitted to
contain the conductors of a 2-wire branch circuit, or one
multiwire branch circuit, supplying the connected luminaires
and need not be listed as a raceway. One additional
2-wire branch circuit separately supplying one or more of
the connected luminaires shall also be permitted
