don_resqcapt19 said:Where do I find that product in Chapter 3? If it is not there, it can't be used.
Don
Don324.1 Scope
This article covers a field-installed wiring system for branch circuits incorporating Type FCC cable and associated accessories as defined by the article. The wiring system is designed for installation under carpet squares.
don_resqcapt19 said:Trevor,
I am aware of that article but it does not cover this application.
Don
JohnJ0906 said:"Currently going through UL/NEC process"
Hope it takes a real long time-looks like trouble waiting to happen.
realolman said:Do you think it will make it? It seems that it would be inherently dangerous.
Pierre C Belarge said:When products come out and get the RTL listing between code cycles, it does not mean they cannot be installed. The AHJ would then be able to sign off on it. That is the power of getting a listing.
I have heard from an employee of an RTL that this product has a good chance of passing the test process for the listing.
I believe they think this will become a big seller in the "big box" stores.
That is why it seems to me to be inherently unsafe.... to protect it from physical damage would defeat it's reason for existance... It would almost be wiremold.iwire said:...The NEC may well add it to Chapter 3 with severe limitations to it use, requirements for protection from physical damage etc. ...
iwire said:Now that is scary.
