art
- California
- Electrical Engineer
I have a 6 conductor cable with an outside diameter of 0.41". it's for a traffic signal radar detector and also carries voltage between 10-28 Volts I think it's considered Power over Ethernet (POE). First, is it communications cable under Article 800? if it is, I believe it has to be separated from the signal and lighting conductors. I plan on using flex if required. Everything has to fit in a 2" conduit. Second, what is the maximum conduit fill for flex?
