Will B
- Fremont, CA
3" flex was run from the 800 amp, 480V switchgear through the 2nd floor to a Jbox in the ceiling below. In the switchgear, the core and KO in the floor of the switchgear are the same diameter, which is also too small for a 3" flex connector. As you can see in the picture, the electrical contractor installed the flex connector, but has it resting on the bottom of the switchgear, unsupported.
I couldn't find any code violation, but I do believe that a bonding bushing on the flex connector is required. Not sure why they didn't at least install EMT sleeves through the floor and then convert to flex instead. Can you guys comment on the install?
Thanks!
PS - Sorry if the picture is too large for some, it looks just right on my screen.
Thanks!
