megloff11x
We have a motor attached to a device that will move quite vigorously. The device will be installed in a Class I Division 2 location. Obviously robust flexible cable, properly supported, between the motor and the enclosure is the solution, but what products are availble for making the transition into the control enclosure (which will be purged and pressurized)?
Most of the connectors I've seen are not rated 480V 60A. The pigtail coming off the motor is shielded too.
Matt
Matt
