cottora
- Atlanta, GA
Our buildings have multiple 36" exhaust "box fans" (think warehouse fan). The fans are installed with wingnuts so that they can be removed for maintenance (monthly/quarterly). We would like to wire a flexible cord that plugs into a PDU which will be mounted horizontally on the wall. All wire sizing is sufficient, and the PDU is listed and sufficient for the fans (the PDU does not specify fans, just power distribution). I know that using flexible cord is only allowable under certain criteria. Is the fact that the fans are able to be easily removed for maintenance qualify for flex (or would it be viewed with the lens of how the fans are "usually" installed drive the decision)? Attached are pics. Thanks
