Greg Gniewkowski
- Ford Motor Company
- Industrial Electrician
Hello. Looking for advice & counsel for the following problem I have in our home. All of the LED bulbs will 'flicker' slightly but enough to be noticeable - no strobe effect. Like watching the light level click up or down by a factor of 1; nothing major but slightly annoying. Some background on our home; built 1971 with all aluminum wiring from meter socket to main panel and all throughout the home. Standard 120/240VAC 150A service. It is more noticeable when a resistive load is plugged in (clothes iron, coffee pot, dryer) or when the HVAC fan motor runs. I have done a thermal scan of the main with a FLIR camera I have and also checked the incoming V with a Fluke True RMS DMM - did not notice any significant changes in temp with FLIR, and V levels fluctuated @ 0.4~0.8 with the DMM held steady on the main lugs for @30 seconds. I am making an educated guess that what is happening is - due to minor V level fluctuations that older Incandescent bulbs would not have been affected by, that the V level changes are causing the internal circuitry of the LED bulbs to constantly adjust due to V levels and that this is causing the current problem. Can I correct this problem by putting an SPD in the main panel or is there some other method I should consider. Any advice I can get would be appreciated. Thank You.
