went on a service call today - customer has a series of lights and receptacles that for no apparent reason flicker repeatedly on and off then sudenly just go off for about 30 seconds then back on. looked for loose neutral in panel, problem breaker, overloaded circuit -found none of those conditions. when the power went off i tested a receptacle and found no power at all but did read continuity from neutral to hot through my tester. the lights and receptacle affected are not all on the same circuit and each time it happens it involves the same group.
any suggestions as to what is happening and how to solve
thanks wouter
thanks wouter
