Electric_kool_aid
- Washington
- Journeyman 02
So I did a full rewire at an older home (40’s). The flipper didn’t want to update the service if not necessary it was a newer maybe early 2000’s Eaton panel. When the customer turns the dishwasher on the kitchen cans flicker. They are on a diva dimmer (led compatible) and the can trims are just standard 3k led trims. Can’t seem to figure out every connection is solid at the panel, not getting any irregular voltage to anything. Obviously dishwasher is on its own dedicated circuit separate from lighting. There is a switch box that both circuits are in and I’m wondering if the dimmer is ultra sensitive to the current pull from the dishwasher motor. Any advice on how to fix this have t really ran into it before. But main service and connections seem solid. Maybe move my arc fault lighting load to a separate pull as the dishwasher ? Replace the dimmer? Replace the AFCI breaker? No other lights in the home are having issues
