concentric
- Charlotte, NC
Hello!
About 6 months ago, we ran some new wiring in a home that had water damage. Old aluminum wire, so added purple wirenuts to everything we worked on in that circuit and we added 4 recess cans/switch to the circuit. Now the cans and a plugged in lamp are flickering intermittently. We tested voltage on everything and made sure panel connections are tight (old Federal Pacific). I'm getting 120v consistently across the circuit and we also replaced all old receptacles with new and added copper tails/purple wirenuts to everything on circuit. I'm at a loss as to what could be causing this. Two days later and homeowner says it's not as bad, but still does it every now and then. Could this be anything besides a loose neutral on this circuit that I just haven't found yet? Thanks guys!
Sent from my iPad using Tapatalk
