We just finished a custom home with 2 - 200Amp panels. I noticed that on occassion the lights throughout the house would flicker very rapidly, almost unnoticable, then after a few minutes they would stop flickering. I began checking loads on everything from individual circuits to total load at the meter. I turned on as much load as possible, including ALL 4 air handlers with as much as 15KW of heat on a single AHU. The lights never dimmed, flickered or anything. Then we turned on the hot water at one of the sinks and the lights began flickering again. The house is equipped with 4 - 60 Amp insta-hot water heaters. I then turned off all other breakers except the insta-hots and the lighting circuits. 2 of the 4 insta-hots would make the lights flicker. With only a total of 48 amps load on the panel the lights would still flicker. One of the water heaters is in a different panel than the lighting circuits but still causes all the lights to flicker rapidly. The 2 panels are fed seperately from a single meter with double barrel lugs. The service is an existing one from when the house was originally built, the house has since been ENTIRELY renovated. The lugs have been checked and seem to be tight. Any suggestions on what the problem may be would be awesome, and I will check the thread regularly to answer any questions, thank you.
