Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
This is inside the water tank, its purpose is to activate 2 water wells.
Almost always they are wired into a contactor at the pump control.
I have an in ground pull box where the branch circuits from the panel split to the two different wells. The pull box is right next to the water tank that is getting the float switch.
Is there any reason that I can’t wire the float switch in series with the branch circuit conductors in the pull box? I can’t think of any reason not to, I just haven’t seen it done like that that I can remember.
Each well pump has its own 20A branch circuit, so I would need 2 float switches of course.
