Johnnewcomb62
- Arley, Alabama
- Electrical Contractor
Hello all,
I have recently moved to a new home semi retiring on a lake but am still actively working and have run into an issue I can't find much information on so I am posting this to see if anyone knows the correct way to go about these situations I have encountered since moving here.
First of all we are really out in the country and there is no inspectors or inspections on anything out here which is very concerning to say the least. But the main issues out here of course are the boat docks which this lakes level goes up and down so everyone has floating type boat docks here. I have looked at a few since I have moved here and NONE of them are grounded as code requires with the #6 wire going from all metal parts back to the originating source or at least that is how I read it. The current folks working on the docks out here have said that if you do that it will energize the dock. The electric company out here sometimes and in some places the way I understand it will actually have a voltage on the ground so if you ground the dock structure you will be actually energizing the structure so they all isolate all the circuits as to have none of the metal parts grounded. Which again is very concerning to me. So I have steered away from working on these since if you do it according to code everyone is saying it will create a shock hazard for the owner and if we isolate the circuits as everyone else is doing and they have a fault then we of course will get sued I'm sure for not doing the job as code requires.
So my question is am I totally wrong in thinking that they should be grounded as code states or is there some exception or none requirement that I am missing or don't understand. I don't really know how the power companies supply somehow energizes the ground wire from time to time but it is happening and just was wanting someone with more knowledge than me to maybe tell me how we can do these under these circumstances where most of all no one gets hurt and of course a lawsuit isn't a major threat ?
Thanks in advance
John Newcomb
Thanks in advance
John Newcomb
