monsagrati
- Norwalk CA US
My house old built 1957 is 2 wire with a ground wire that is in the attic going wherever.
I added some lights in the bath and discovered I have a floating ground measures 120VAC no load 12VAC loaded it gives a jolt. I refered to the code when adding 2 conductor with ground to existing 2 wire no ground bond the grounds to the box and fixture I did. found the ground unloaded has 120 VAC and ohms out at 9.6 M Ohm.
Not exactly sure of the proper way to deal with this.
I Could add a light in series on the ground wire I m sure this isn't ethical practice.
Any feedback is appreciated.
Regards,
Mike SO Cali
Regards,
Mike SO Cali
