2001 residential home has existing flood light fixture mounted on screen enclosure At least 10' plus away from edge of water on G.F.I. breaker and about 10' above water level on outside of cage. It is Rigidly attached I can't see anything wrong with this. There is a #8 bond wire attached to enclosure going to pool steel back to pool pump. looks like a good installation. at one point the cage is 3' plus away from waters edge but remember it has #8 bond. Wiring is in pvc conduit with insulated #12 ground wire. Perhaps I am over thinking this. Picture pool with 3' raised concrete build up above ground because of sloped back yard. Does anyone see something wrong with this I would like to know. I have read the 2002 nec hand book that was not even in effect at the time seams ok.
