Floor box receptacle in shag carpet
smallfish
Detroit
Is there a floor box receptacle for other than wood floors and commercial 3/8 inch thick carpet installations?
To be more exact, what floor box receptacle can be used with a thicker carpet than a 3/8 inch thick carpet?
Thanks
I use the standard floor receptacle.
Thanks
Any good floor box will adjust to whatever floor finish is being installed carpert or vinal or tile.
Why use it if you don't need it?
Because in the places I work I would give the cover you posted about a day before it was bent, broken, or missing. :)
Now true enough, considering this is about Shag carpet I doubt it is commercial but the carpet flange I posted would keep the shag back from the receptacle nicely.
It also looks like a 2 gang opening. How does this work Bob?
Single gang, follow this link http://www.hubbell-wiring.com/htm/CommFloorboxes.htm turn to pages 428 and 430.:)
