ZSIM
- United States
- Electrical Engineer
Greetings. I am looking to learn something about floor boxes that perhaps I've been negligent of in my career so far.
I've always been under the impression that floor boxes, when installed in slab-on-grade concrete flooring, utilized "in-slab" raceway. It is not something I've come across often, but the products I've seen from Legrand, Arlington, etc. usually depict and suggest the raceway running in the slab.
I have an individual however who is telling me that we should never run the conduit in-slab; the raceway should always be run under the slab (for both new work and old work). In their judgement for an existing facility you would cut the slab from box location to wall, but then trench down slightly to install the raceway in the base/subbase under the pad.
I cannot find a product that necessarily supports this method of installation, and it seems to add significant labor plus the possibility of moisture ingress into the raceway system by being in the mediums under the slab... but I am very inexperienced here and looking for what the better approach generally is considered.
What is your preference (in-slab or under slab) and which do find to be the superior installation method? Thank you.
