enireh
- Canyon Lake,TX
in the bathroom we have a gfci outlet on a switch which operates two lights plugged into it. I plugged a floor fan in and it works unless I unplug the light unplug light and fan stops
Try moving the plug for the fan to the outlet where the light is plugged in and move the light to the one the fan was plugged in to.
Then unplug the fan and see if the light goes off.
that has all been done at first it is in outlet with light, light is unplugged and fan stops, I move it down the line same gfi circuit with another light, unplug light same thing, took it into other bathroom with gfi oulet and same thing the fan does not have a light sensor
Now you're confusing me. How do you plug into the line side of a gfci?
wag, but the gfci outlet is bad and one half is being backfed thru the light load. ofc easy way to test is plug both lights back in and then unplug 'line side' light -the other light would go out as the fan stopped.
done that the light down stream always works with out the light at line side in, without anything in line side outlet, curling irons, hair dryers, etc., all work only fan does this
poor wording on my part. gfci (especially older ones) can fail almost every way imaginable, and some that are head scratchers. by line side, i meant that only half the receptacle is hot due to failure (load side neutral is a usual suspect). as long as 2 loads are plugged in, they both work, but unplugging one (line side or better yet "still working half") can kill the other. unless half of the receptacle circuit is switched, which the op didnt mention. i dont see any other viable options, other than damaged fan cord/plug and coincidence with removal of lights/use as test eqpt. could be a good receptacle/bad wiring, tho if it were the lights would not work either.
I'm getting confused. You said you moved it to another bath with GFCI and it worked, now you say "same thing" meaning the fan stops.
Is the GFCI receptacle a duplex receptacle (two places to plug in)?
Does the light have a cord that plugs into the GFCI?
If it is a duplex GFCI then do as I suggested and "swap" the light & fan plugs. Then unplug the fan and see if the light goes out.
Or do as jfletcher mentioned, plug in two lights (or 2 of anything) unplug whatever is plugged in to where the light was originally plugged in then see if the other item goes off or stops.
I'm trying to see if the GFCI is bad (mentioned by jfletcher), which sounds like it is if you have a duplex GFCI.
I've seen the neutral fail on the load side before and in your case it works as long as something is plugged in on the line side.
yes the light has a two pronged cord,
eta: receptacle could have had line side hot/load side neutral landed on line side terminals or similar wiring error. older gfci do odd things when they fail. new ones just refuse to energize/reset
as far as troubleshooting, i would have already replaced the gfci. op needs at least a gfci plug tester to ensure downstream receptacles are protected; fans, lights, etc do not cut it here.
going to change but I was wondering why is it only the fan does not work? other appliances do thank you all of you for your help and I apologize for my wording
