A/A Fuel GTX
- WI & AZ
- Electrician
If I'm not mistaken, the next joist is an I-truss. Two 2x3s with a particle-board web. You can just see the glue joint.The gusset plates make it look like a prefabricated/engineered wall, similar to a truss design . . .
I would not call it a truss, specifically because it is not spanning anything. There is absolutely no need for stiffness or shear strength.It's a floor truss.
Functionally there is no problem with drilling because it's sitting on top of the foundation instead of spanning, but an inspector could take issue with it
I agree, but to be picky it would be OSB for the web and not particle board.If I'm not mistaken, the next joist is an I-truss. Two 2x3s with a particle-board web. You can just see the glue joint.
I agrre about the span, and almost mentioned that specifically. You're probably right as to what it's called technically.I would not call it a truss, specifically because it is not spanning anything. There is absolutely no need for stiffness or shear strength.
It is a short wall.
In earthquake areas it may be necessary to add shear paneling to it, but that would make it a shear wall, not a truss.
I know this has nothing to do with the OP.
Is it common to rough in partitions directly on the dirt in your area?
I've never seen that done before except for DIY's.
Feel free to correct me if that's not what I am seeing.
Those partition walls you see in the basement are on concrete footings.I know this has nothing to do with the OP.
I agree with you but the location of the service on this house leaves me no choice but to drill the Jack wall to run the SEU from the meter to the panel in the basement.I see what looks like concrete footers under each partition when I blow up image, a lot of dirt around and on them though. Surprised that there wasn't a full pour done, or any vapor barrier put down. Around here would have all sorts of moisture issues and then mold.
To the OP is there a reason you want to drill thru the Jack wall, instead of running in between the joists parallel to the wall? Wall likely load barring given it sits on the footer, but as already suggested strategically drilling for wire placement shouldn't compromise the load barring (do that everytime we drill thru an exterior wall) unless contractor used undersized or bare minimum load capacity components compared to engineering specifications. But if concerned reach out to the engineers that designed the structure for confirmation and limitations.
Got it.Those partition walls you see in the basement are on concrete footings.
I agree, that wall is too close to the dirt for my location. ...
That's the construction, but it's not being used as a beam element, it's being used as a wall. So while I agree that it is worth checking with the designer, it should be OK to treat the same as any wall.That is a ladder truss.
Or a “gable end truss”
All gable end floor trusses I have installed are essentially “walls”.That's the construction, but it's not being used as a beam element, it's being used as a wall. So while I agree that it is worth checking with the designer, it should be OK to treat the same as any wall.
Cheers, Wayne
