A/A Fuel GTX
- WI & AZ
- Electrician
I'm pretty sure the NEC doesn't address this but maybe someone knows the answer to this question. When a structure uses the wooden " I Beam " type of floor joists, is there any limitation on what size hole can be bored through the joist? These are the type that are made out of particle board and have pre punched ko's every so often along the span.
