We have a project to power (3) soccer field - pole lights. The lights are controlled by anoutdoor relay cabinet (50"H x 20"W x 8"D). The relay cabinet mounting option is surface mounted only. The client wants this relay cabinet to be pad mounted. Is there an outdoor pad mounted cabinet we can use to mount this relay panel inside? Any recommended vendors, products to make this work will be appreciated. Thank you.
