ceb
- raeford,nc
I need help! I have installed 8 two tube 8 ft. fixtures all new. I have one that is giving me a fit and I need any ideas that will help. This one fixture worked fine for a few days then after it was on for 30 min. or so it would go out stay off for a while then come back on. ok bad ballast removed ballast took it back to supplier, new ballast same brand,numbers every thing,installed light came on stayed on, few days later light off, removed tubes and could hear filament sliding around in tube,replaced tubes turned on switch,POW,tube blows, replace ballast
,check volts 121.7 check all connections,re twist put wire nuts back on,install new tubes, light on for about 30 min. then off and ballast humming so loud it could be heard from 40 ft. away, check all connections again light will not come on.what is going on? any ideas?
