Hey Folks,
I have had a big problem with finding an answer to this so I've been going overboard with safety precautions which is becoming very aggravating and extremely time-consuming doing it this way. So here it is...
Problem
Outlet on the left side of the room. You need to create new outlet 7 feet away for example running horizontally as going up and over won't work as the ceilings are concrete also.. The problem is when you make the outlet hole for the new one you find if there is a masonary cindeblock wall. You have no access to any of the cavities in the block but that wouldn't matter because you've got to take the run left and pass over two sets of furring strips that is holding up the drywall. Keep in mind we're relocating an outlet for a home theater system so it has to be aesthetically pleasing.
The only space that you have available to you is between the Drywall and the Masonary wall which is only a quarter of an inch.
My research
NEC 300.4 (A) (1) this code states that if you're passing through a framing member and Less than 1-1/4 inches away from the Drywall you need to have a 1/16 plate to protect it from any nails and screws where they are likely to penetrate. Unless you consider the furring strip to be that framing member I don't know if this applies. It gets tricky because NEC 334.10. (a)(2) states that you can fish between the air voids of the cinderblock but we don't have access to that either unless we break a hole thru it and hope that are lines up so you can fish through the webbing.
To make it even more complicated 334.10(2) prohibits NM cable in type I and II, would this be considered type I or II since interior walls are not concrete?
I am so darn confused about this whole topic and the way I've been dealing with it is by trying to fish armor cabling behind the wall and destroying the openings and drywall just to be safe because I feel like anyone can penetrate the drywall and hit a cable. I would hate for someone to get hurt because I've violated the code but it's so unclear.
Please help!
Problem
My research
Please help!
