</font><font size="2" face="Verdana, Helvetica, sans-serif">
- <font size="2" face="Verdana, Helvetica, sans-serif">Use with Lutron Hi-lume and Eco-10 line voltage control electronic dimming ballasts only</font>
So, you wanna bet my supply gotten us 2 $80 dimmers when a simple dimmer would do just fine?GE Dimmable CFL ? Compact, fluoro, dimmable! Wow!
First we got the CFL! It was amazing because it replaced standard incandescent bulbs and used much less energy. But it was much longer than a bulb, and would not fit a lot of standard light fittings. Then out came the compact fluoro lamp. Closer in size to a standard bulb, it offered energy savings and fitted a wider range of light fittings. But you couldn?t dim it.
Now, GE has taken the next step and brought out a compact fluoro lamp that can be dimmed! The GE Dimmable CFL is designed to operate on standard incandescent dimmers and offers wide dimming across a continuous range between 20?100%. Available with either Edison screw or bayonet cap base, the GE Dimmable CFL comes in 13 or 20 watt, in warm white or daylight colours and boasts an average service life of about 8,000 hours (on average). Compare that with a incandescent bulb.
Nice one, GE!
Peteo, what this professor has to say is nothing new.Originally posted by peteo:
A professor from Hong Kong, it seems, is the one with something to say:
http://www.building.com.hk/forum/07_00electronic.htm
You can not dim a standard magnetic ballast, you can dim some electronic ballasts, they are capable of changing the frequency, current and voltage supplied to the lamps.Originally posted by pasha:
Mr. Steve explanation that dimming is obtained by varying the current, because the ballast of a flourescent lamp is inductive in nature and inductive reactance Xl=2xpiexfrequecyxinductance.
I have installed many dimming florescent fixtures.Originally posted by georgestolz:
So, has anybody worked with the dimmable compact fluorescent lamps? Is my read on this correct, that they all use regular incandescent dimmers?
