Re: Fluctuating voltage
Thanks guys for your input. I'm a home inspector and I test circuits on new construction primarily looking for potential problems, and when found, defer it to a qualified electrician. I do not have troubleshooting experience due to SureTest findings and am hoping for some enlightenment from those who do.
mdshunk said: "Given all the recent goofy reports about the SureTest, I'm not sure that it has much value." Can you elaborate just a little?
Jim, This problem occurs only on certain outlets and is repeatable. Would that rule out a defective analyzer?
Since the SureTest measures the circuit voltage under a load, could the fluctuations also indicate a poor connection in the wiring? I was testing the circuits in a new house when I ran across this fluctuation issue. I also had 0~14.9% voltage drop on the circuits at various receptacles, and on some duplex receptacles the voltage drop varied as much as 2.2% between the top and bottom outlets.
Assuming that the SureTest is giving accurate readings, what are the most common causes of fluctuating current and voltage drop differential between the two outlets on a duplex receptacle?
Thanks again!
Duane
