Saturn_Europa
- Fishing Industry
- Electrician Limited License NC, QMED Electrician
I am using a Fluke 1507 Insulation Tester for the first time. I am using it to test a motor that has a short to ground. The switch board shows a short whenever the motor is running. I am going to replace the motor.
With the Fluke 1507 set to 1000 volts it is showing a reading of around 0.4 M ohms on each leg to ground. The voltage on the display of the meter will only go to around 514 volts.
I am suspecting the 1507 wont put out the full 1000v because it is sensing a ground?
Whats the rule of thumb on good/bad megger readings on motors?
