fbhwt
Electrical Systems Inspector
- Spotsylvania,Virginia
- Electrical Systems Inspector
I just recently acquired this Fluke earth/ground tester. The quick reference guide that came with the tester shows the cable connection to the ground stake. The problem is the ground stake is a "T" configuration with a threaded hole with screw on one end and just a hole, not threaded on the other. The one end of the cable has a jack that obviously connects to the meter, the other has a "banana" type jack. The banana type jack will not fit in the non-threaded hole and is very loose in the threaded hole. Has anyone else had this issue with their meter or am I just not doing something right.
