Alwayslearningelec
- NJ
- Estimator
For the apprenticeship they have a list of tools and one of the items is a Fluke T5-600 or equivalent. Is this a good one for the $$$?
I still like the more-compact Knopp K-60, now CAT-III rated.So for basic voltage measurements I'll use a VolCon instead of the T5.
That said, nether of those meters compare to the T-5, ohms and amps are handy.
Where is the cheapest place to buy the T5??
Thanks.
Yeah, I'm thinking of chucking the VolCon in favor of the T+ to complement the T5 I already have.
Does it do continuity? I don't bother with any tester that does not have a continuity feature.
You both know I'm a fan of the wiggy-and-extension-cord method. Plus, if a receptacle is dead because of a cut cable, it'll likely involve more than one receptacle.But like Pete I must have the continuity feature. When troubleshooting a 'dead outlet' call one of my first moves (after voltage checks) is a neutral to ground continuity check because if you don't have that there is a good chance the circuit is no longer connected to a panel at all.
