Dsg319
- West Virginia
- Wv Master “lectrician”
Having an issue with my fluke twistguard Tl175meter leads. Have loved them up into this point, super flexible and bendable with no memory of the bends.
Plan on doing some bench test this weekend during the rain, and noticed tonight that when I went to “ohm out” my leads together. I was getting higher than average values. Around 2-2.5ohms.
So I replaced with original leads that came with my fluke 117 and almost zero’d my ohm readings back to 0.5ohms +/- a little bit.
Some test to assure it was the leads and not the meter consisted of.
1.Removing the com lead and placing tip of red lead into it just to test that single lead itself. And there lied almost all the resistance I was reading in the red lead.
Black lead still was 0.9ohms.
2. Replaced with original leads from fluke 117, read resistance across the fluke TL175 and read the same values as when they were plugged into the meter. Around 2.5ohms.
3.Also plugged the TL175 into another meter and read around the same high values for just the leads themselves.
What could cause this? There not that old, clean and always well taken care of.
