I have a project with fluorescent lighting connected to a panel backed by a generator (emergency source). During testing, transfer from normal power to emer power is OK. When transfering back to the normal power source the transfer caused the multivolt, programmable start, electronic fluorescent ballasts to go crazy, provide limited light output from the lamps and flicker. Turning the power off then back on fixed the problem. The transfer switch causes a voltage dip for the instant during transfer which seems to make the ballasts go crazy. Has anyone else run into this problem and what was the fix?
