urssynovec
I have a lighting installation that I don't like and need to know if its code compliant.
Fluorescent light strips have been hung in an open ceilng Parts Storage Room. The strips have been suspended from the deck using chain with the strips about 12' apart. The strips are about 8' above the floor. The strips were used as raceways for the luminaires. Power to the strips was run perpendicular to the strips using one EMT run from a wall at the same height as the luminaires. The conduits run from strip to strip with connections in on J-box at the end of each strip.
I would have preferred the conduit run on structure above and pigtails dropped to the luminaire J-boxes. I could not find anything in the code support or deny the actual installation method. Does anyone know of anything in the code that applies to this situation?
I am pushing for at least the first conduit run from the wall to the first strip to be partially run in flex. I feel the EMT should be used to protect the conductors but not to be the only resistance to lateral movement if the fixtures are hit by a forklift or parts room personnel. Does the code give me any provisions to require this?
