This isn't a specific code question, but I was wondering if T-30 lamps will work if it is run from a T-25 electronic ballast? If it does, will it prematurely burn out the bulb? I currently have a 36 inch 2-lamp fixture with F-30 T-12's and a standard ballast, and wanted to know if I change out the ballast to an electronic ballast if I would need to change to T-8's or could I stay with the T-12's. Thanks.
