In mechanics shop with a high ceiling, and high ambient temperature, can't keep fluorescents from burning out (8 foot fluorescents). The lights are mounted direct to the sheetrock and need to be as tall as possible for clearance of large trucks. The garage doors are open continuously here so the temperature range is from about 30 on a low in winter, to about 130+ in the summer (110 here in the desert southwest yesterday)
Owner says the ballasts and bulbs have been changed to many times to count. Only easy solution to assist keeping the ballasts cooler would be to mount the fixtures on a 7/8" piece of strut. I don't thing it will matter that much.
Only serious load draw on the system is 3 phase large air compressor that is always seen in the incadescent lights when the compressor kicks on.
The shop has a bolt on 225 A panel ancient Square D panel, and all the gear is tight. The power from the utility is 3 phase Delta, with a wild leg. Various times of the day have turned up various voltage readings. On the wild leg, I've read as high as 215 volts in the evening, and as as low as 207 volts mid-day. The two other legs have read anywhere from 114 to 125 volts.
The owner would be willing to buy new lights if he new they would work. I'm looking for a reasonbly priced fixture, and lamp set up that will work for him in a flourescent fixture style, or recommendations to solve the problem at hand now. Thanks in advance for all recommendations to solutions, or replacements, that will work.
