Trying to figure a way to install a flush mount panel in a outbuilding wall that will be finished with barn steel.
The steel has a raised portion( about 3/4" high) on 9" centers.
Can't visualize a clean, flat fitting cover over the steel.
Any suggestions?
What are you not following? fireryan's post or mine?Not following...
Not following.
I have a means to support the panel. I am wondering how the 3/4" raised portion on 9" centers will allow the cover to fit tight.
When the cover rests on the higher profile, there will be a 3/4" void.
How does the strut benefit?
My inkling was that he wanted better aesthetics than J-channel trim.Use the same J channel (or have those installing the sheet metal anyway) around your flush panel as is used around other openings in the wall. If your J channel is ~3/4 inch deep then your box needs spaced that far beyond the stud or furring strips that the sheet metal attaches to.
I read what you posted again - sort of similar idea either way so take your pick at which looks better.My inkling was that he wanted better aesthetics than J-channel trim.
