All I just thought of this situation:
1) suppose you have two flux vector drives each has a dynamic braking resistor and a respective motor. Both motors are coupled to some machinery. Only one motor operates at a time, the other just goes for the ride. Then they alternate, next cycle the second motor does the work. When the two motors are coupled like this and the second motor is being back driven, assuming the second drive is not enabled will there be any rise in the DC bus voltage and subsequently turning on of the dynamic braking transistor and use of the second motors dynamic braking resistor?
2) suppose the same situation as about but the second motor is a reduced size motor with a gear box with reduction in front of it, say 2:1, such that if the main motor is running at 1175rpm the second is being back driven at 2350rpm, does anything change with the scenario?
