I have an application where I need to install 2 #12 control wires vertically in an existing building. The vertical distance is about 125 feet. The wires would be run in FMC conduit through an existing vertical chase. The chase only has access in the bottom and top. Per NEC 348.30(A) exception 1 there is no support distance requirement. Though allowed by the NEC it seems that the weight would be excessive. Has anyone ever had an application like this?
