FMC in Elevator Machine Room
cvirgil467
NewYork
I noticed FMC being used as the main feeder to an elevator from a distribution board. The feeder (in FMC) is routed from a distribution board and terminates in a disconnect switch in the elevator machine room.
Per the 2005 NEC section 620.21(3) - i think this might be a violation unless the distance limitations noted are only related to the liquidtight.
Any thoughts?
Thanks.
C
Note 620.21(A)(3) is only addressing from the load side of the disconnect.
Roger
Any thoughts?
Thanks.
C
Key word within "Machine Rooms" and the exception is "LFNC" and 6' is the limitation on FMC within the "Machine Room"
