jwelectric
- North Carolina
The NEC Process
The NEC is developed through a consensus process approved by the American National Standards Institute (ANSI). Any person of the public can summit a proposal for a change to the NEC. All proposals are organized by the National Fire Protection Association (NFPA) and sent to the nineteen Technical Committees also known a Code-Making Panels (CMP). The Code-Making Panels will take one of five actions on the proposals; accept, accept in principle, accept in part, accept in principle in part or reject. Should the Code-Making Panel reject a proposal they must issue a written explanation on the rejected proposal. It takes a two thirds approval vote in order to take action on a proposal.
A report on the proposals is sent to the Technical Correlating Committee where they check for any conflicting actions. The Report on Proposals is then written and distributed.
Comments on the ROP are then made and organized by the NFPA and returned to the Code-Making Panels. Again these meetings are open to all who are interested. At this stage there is one more action that the CMP can take. The CMP can put a comment on Hold which would return it to the next code cycle as a proposal. The CMP will then return the comments to the Technical Correlating Committee where they will check them again for conflicts before returning them to NFPA for approval. Any amendments made by the NFPA will be sent back to the proper CMP for their approval.
A couple points of interest about this process, one is that beside each name of the CMP listed in the front of the NEC is a letter in brackets, example John Doe [SE]. Here is an abbreviated list of these letters; M-Manufactures, U-Users, I/M-Installers & Maintainers, R/T- Researchers & Testers, E- Inspectors Enforcers. Take note that ?AHJ? is not in any CMP, I suppose that the code makers call the ?inspector? inspector. Second, there seems to be a lot of manufactures, ?sellers?.
Edited to say
Comments on accuracy are welcome.
[ January 22, 2005, 08:28 PM: Message edited by: jwelectric ]
Edited to say
