Got a call to give an estimate on adding additional electrical to an existing food/ concession trailer.
Existing is wired in NM cable ( concealed behind walls and ceiling) , wiring from outside power inlet box is 6/4SO cord also concealed. 50 amp inlet.
It appears to have been manufactured and not a DIY project.
Apparently it didn’t have to be wired to any particular code when it left the factory.
There will be about 10K watts of total load if everything runs simultaneously.
My suggestion to the owner is a generator with 12K watt running capacity.
Would a generator with peak output of 15KW cause an issue with the inlet box size ?
