Thanks guys.
I see where the requirement is: 250.52(A)(3)
A #4 on their combination of 3/4" and 1/2" rebars was installed. As I was not onsite today, the GC and mason installed the wire prior to the pour...that pour should be done by now.
I missed the inspector, but the GC asked him the same questions I had:
Q: What's the point?
A: I don't know..I'm just here to enforce the code.
While I recognize the Articles (250.50 and 250.52(A)(3) )...what is the point?
Of note....although possibly not of any consequence...this commentary follows 210.50 in the '02 NECH:
Formal Interpretation 78-4
Reference: Article 250.50
Question: Is it the intent of 250.50 that reinforcing steel, if used in a building footing, must be made available for grounding?
Answer: No.
Issue Edition: 1978
Reference: 250-81
Issue Date: March 1980
This commentary is NOT in the '05 NECH...and may have been rendered void by changes for '02 - '05:
210.50 '02:
Grounding Electrode System.
If available on the premises at each building or structure served, each item in 250.52(A)(1) through (A)(6) shall be bonded together to form the grounding electrode system. Where none of these electrodes are available, one or more of the electrodes specified in 250.52(A)(4) through (A)(7) shall be installed and used.
210.50 '05:
All grounding electrodes as described in 250.52(A)(1) through (A)(6) that are present at each building or structure served shall be bonded together to form the grounding electrode system. Where none of these grounding electrodes exist, one or more of the grounding electrodes specified in 250.52(A)(4) through (A)(7) shall be installed and used.
Exception: Concrete-encased electrodes of existing buildings or structures shall not be required to be part of the grounding electrode system where the steel reinforcing bars or rods are not accessible for use without disturbing the concrete.
The change from
If available to
All grounding electrodes...
that are present, seems (to me) to void the Formal Interpretation 78-4.
Inspite of all this..I still fail to see "What's the point?"
