brycenesbitt
- United States
Ok, this question might take a moment to ask, forgive the buildup.
I'm working on specifications for adding EV circuits to existing apartment buildings.
These have 200-600A main split phase service entrances, 60A to 100A meter bases, and 30A to 100A main breakers per apartment. There may or may not be a subpanel, but if there is it's likely 50A and more than half the buildings use FPE breakers (with the next most common being Zinsco). The main breakers are sometimes FPE as well, but are sometimes singular. There's the occasion 3 phase main, but mostly it's split phase.
The goal is to place each new EV circuit "behind the tenant meter" for a variety of reasons most notably convenience for the tenant, and access to their tariff.
The question is what tap or splice connectors would you recommend for the confined and varied spaces? Which ones really work well, don't take too much space, and hold tight? In some cases the tap will be after the tenant main breaker. In as many cases the tap will between the tenant 60A meter base and the 30A or so main breaker thus drawing more power than before through the meter base. I hope that it's possible to upgrade some main breakers to modern specifications, but that's really a separate concern.
I've attached a few typical photos of such vintage panels. The overall house amperage is not a concern, just the process of stubbing for the EVSE EV circuit:
